Carbonated Solutions
Did another job with it the other day mixed it up into a 5 quart 4-1 hydroforce I'm guessing about 5 gallons of pre spray, If mixed this way the $110.00 bulk, can make 20 full hydroforce pre mix's and do about 20 avg. houses.
http://www.carbonatedsolutions.com/members/#!/Bulk-Cleaner/p/9654149/category=0
I thought I got a photo but can't find it, needless to say we sprayed down a moderately soiled carpet followed with the CRB and fresh water rinsed. There were some small pet stains to clean up real nice.
I'm almost to the point no matter what you mix the CRB is awesome. But I'm really leaning towards using this on the mild to moderates.
Ne
In my tests the carbonation just fizzes out right away. And a spray bottle mixed up sprayed on some glass showed a sticky residue.
Scott S.
PA
Scott
You need a stick residue.
To hold down those contaminates you're worried about blowing around the house while vacuuming.
Idiot!
you guys even read the sds sheet for the product? pretty basic ingredients. i have a sample i just got and have to try it out sometime this week or next. waiting for a perfect situation for it and some other products.
Ne
Simple ingredients like procyon , cheap to make and charging a premium price?
All to clean a 1/2 inch of plastic fiber.
Smoke and mirrors
Hello?
Zee
SoCal jungle
What bubbles Marty?
I have the same experience as Jimmy. It instantly will fizzle up (almost violently) as you add the powder to the water... and then it is just a smooth liquid.
What bubbles Marty?
Well, next time I ask you a question, just answer it.
Without all the DAQ's.
Ardmore, OK
Rieta Ebberts
If I understand correctly how the HF works...it's basically a syphon-type of machine, correct? If that's the case, it may not be the most effective use of our cleaner. Pre-spray is still going to allow this cleaner to be the most effective and the most cost effective too. I know it's a little counter-intuitive for some of you but honestly, less is more!
