Greg Crowley said:
It has nothing to do with vacuuming
it can, but that's not true filtration soil
it has to do with the way the allergens and pollens and air quality gets in the walls
true... and candle soot, dust, cooking oils, fuel furnace hydrocarbons , etc, etc, etc.
It get's thru the walls just as Sweendoggie said, though.
It's "drawn" thru to due differing air pressures in the home
Maybe it is there locatiuons but most filtration problems I find are in unpopulated areas
maybe so..in Greg's world
but we see them anywhere from apts buildings to farm houses out in the sticks to upscale gated housing associations.....and everything in between
My suggestion ()for what is worth)( is spray with a good 10 or so ph cleaner but use your grout brush along the lines. If that doesn'work get some hel gel and mix 50/50 with water and spray across and scrub,
Prochem filtration and all other filtration cleaners are a waste you would use too much
not bad suggestions, Greg, and I'm inclined to agree.
However, not all filtration soil is created equal.
Some are down right easy to remove, some are damn near impossible (or impossible on some light colored goods) to remove 100%
