So the baby is almost here, so i decided to clean the house. I did an experiment with different drying scenarios in 3 of our 4 rooms.
Room 1-Only air mover for 10 min (about the time it would take to clean next room in your normal house before i move blower)
Room 2- Only ceiling fan
Room 3-NO air mover no ceiling fan
Results (obviously this will very from machine to machine, how much psi your putting down, and the temp of the home)
Room 1 -was dry in about hour to a hour and half with only 10 min of air mover
Room 2- was dry in the same amount of time
Room 3 -took about 3 hours
What i took from this is that putting down an air mover for a measly 10 min in a room will significantly cut your dry times down. I try and preach this to my tech's as much as possible. So especially in a home without ceiling fans make sure to get an airmover down even if you only have one, at least while your cleaning the next room, and then move it again, your customers will love you for it!
Anyone have similar results? Or tried something and got totally different results?
