carpet selection for a resturant
davegillfishing
st augustine fla
dave gill
the customer wants a commercial glue down style but wants pad under it, it is going to be laid over concrete and will not have any tack strip. it will need to be cleaned about every 2 weeks or so because of the massive amount of traffic and the area is only 15' x 29' pretty much a square.
olefin or nylon both for wear, tables and seats being dragged and easiest cleaning/maint
what direction should i point him in?
thanks
seattle
Solution dyed type 6.6 nylon, small pattern, no light colors, particularly no white/off-white, light blue or gray.
Dave, nylon is fine, Olefin is oil loving. color choice is paramount. If they are choosing an off white color, I can see every two weeks. Any other darker color once a month should work. If it is anywhere close to kitchen, dark color burgandy is nice, med. brown works well. Use colors with a pattern also. Its good that you care about their choice, if they picked the wrong carpet, it reflects on your company when your cleaning is not cutting it, due to bad color choice in restaurants by them. good luck, Ron
davegillfishing
st augustine fla
dave gill
it will be light brown..i will need to be cleaned every 2 weeks because of the amount of things spilled..it amazes me when i go in there 3-4 days after we clean it and it looks great other than all the catchup and drink spills..it would be really really bad after a month. resoling has never been a issue just the amount of spills..
Bloomington, IL 61704
C&A powerbond with an RS back.. not the tiles but the 6 ft wide with welded seams no pad and glue to fail, when properly installed. Absolutly not chance of delamination.. Abuse the hell out of the stuff, solution dyed nylon. Clean it every day with out fear of destroying.. and ignore their claims about not being able to use a cimex. The stuff really is indestructable when installed correctly. And will give them the effect they are looking for.
Utah
must not be "those people"
3 mths would be ok :twisted: :twisted: :twisted:
davegillfishing
st augustine fla
dave gill
:?: i must have missed something
Joel D
Oakfield, NY
Joel Darker
Want it over pad but no tackstrip? Does that mean they want to go with a double stick?-(pad glued to floor than carpet glued to pad) if so the installers must not skimp on the glue. These type of installations require lots of glue and their has been huge problems with not using enough, than wrinkling problems later.
Sweendog ive never heard of what youre describing. Six foot wide carpet? Could you explain more?
billyeadon
Indianapolis
Bill Yeadon
Re: carpet selection for a restaurant
I agree with Sweendog on the Tandus C&A product. Th powerbond has an attached cushion. It may be more expensive than they are willing to pay but it is a great product. Plus their head maintenance guy is an IICRC approved CCMT instructor for Jon Don.
http://www.tandus.com/products/sixfoot.aspx
If they can't afford Tandus then yes go with doublestick if it is properly installed.
Collins and Aikmen.. its a super duty commercial carpet. With the fibers heat set into a thermoplastic backing. They are available as a very dense thin back or with an attached urethane vinyl padding thats welded in as well so you basically have a product that is impermeable to moisture.. Its alot better than any double stick installation.. Regardless of how well a double glue installation goes, it will inevitably fail. But there is no adhesive to fail between layers. no latex. And when the proper floor prep is done and sealer, the self stick back is quite permanent until its power stripped off the floor by machine.
An example of C&A
Utah
Dave go read this thread viewtopic.php?f=1&t=27092
then itll make sense and youll laugh your ass off
boazcan
Tampa Bay/Central Florida
Bryan C
Dave,
Tandus - all the way. What Bill said. Email John Garger for the rep in your area. Great to network when you have a live lead with a mill rep. You won't get too much interest unless you have something to offer. It will be a small job, but something is better than nothing.
Email me if you want his contact info.
