Cat 3 Black Water on Porous Surfaces
Doesn't IICRC S500 say all cellulose material should be replaced if significant cat 3 black water exposure. Insurance companies says they won't replace wood submerged in poop water. How often do win or lose this fight? Thanks
kmdineen
Kevin Dineen
When the s-500 refers to cellulose material, it relates to plant cells such as cotton or jute.
When the s-500 uses SHOULD, it is an accepted standard of care but not mandatory by regulatory requirements.
What wood was submerged in cat3 water? Hardwood? Does it have a finish on it? Was it wood wall framing, maybe pressure-treated? Can the wood be cleaned over and under on the sides with a low-pressure spray? Is replacing the wood cheaper than cleaning, drying, and disinfecting? Please provide more information.
