cat pump check valves............
I am looking for a set of check valves that support the high and low pressures switches on my thermalwave.......
What the hell kind of Russian Submarine you running out there Jim?
normal check valves have a raised tip on the top of them........if you have high and low pressure switches.then you need the check valves with a flat surface and a small hole on the top......
spotman123
Jim, when I changed mine out I just sanded down the tip and drilled a small hole in it. Not sure you can buy them that way? Itoo would be curious...
