Jan 11, 2012 #1 Joe Appleby Supportive Member Joined Feb 8, 2007 Messages 608 Name Joe Appleby Anyone using 30 wt. non-detergent oil in your cat pumps?
Jan 11, 2012 #4 A ACE Guest Yes, Draned the oil last time only to find I did not have cat oil. Are others running 30 ND oil still doing changes every 500 hrs or more often?
Jan 11, 2012 #5 Lee Stockwell FOJL Joined Oct 7, 2006 Messages 18,851 Name Lee Stockwell It's so easy to change, and so cheap, I do it every 200-300 hours. Occasionally filter it to check for debris.
Jan 11, 2012 #6 Dolly Llama Number 5 Joined Oct 7, 2006 Messages 31,225 Name Larry Capitoni Joe Appleby said: Anyone using 30 wt. non-detergent oil in your cat pumps? Click to expand... did for years and i use 85wt gear oil in the blower . It's never below 32 degrees and the working environment is always over 200 degrees ..L.T.A.
