It's fixed......I wasn't sure if it ran through a relay or not. It is direct wired to the switch by way of the fuse box. What happened was the radiator was leaking slightly, and it was collecting on the switch backing until it shorted out. So....my ambitious Son decided to pull and change the radiator (I had a spare just lying around, believe it or not), and install new switches (and the thermostat switch) and remount them up on the gauge panel out of the heat and moisture. Should be running in a few hours. 10 tears old and still kickin'! Love that Genesis 59.
