Larry B
Ok so I think I missed the short bus a couple times but reading stuff on the boards has me wondering a couple things.
1. "use a 1.5" whip on a 2" wand".
What the hell would the point be in purchasing a 2" wand if your connecting it to a 1.5" whip and bottle-necking the airflow?
2. "Blower size dont matter because you can only get so much air in the hose"
What about the force behind the amount of air flowing through the hose. Do some of you really think a #3 blower is moving the air through a 2" hose at the same speed and force that a #5 will? If your hose is not collapsing from the suction it can handle more pressure.
3. (for ya green cleaners) "Chemicals are not as important as the heat"
I know the BS works with your customers but please do tell how you think water alone cleans as good as using an emulsifier? Please dont respond with your BS lies about your water temps at 280.
4. (For you padding nut bags) What the hell planet do you live on where grinding a carpet with a 100lb machine makes all the dirt magically jump up onto your little diaper? Does common since not tell you where the dirt is going? Do you go home and laugh after you get customers to believe this BS?
5. "If your not making $100 an hour your a hack"
Not everybody has the same marketing plan or for that matter wants to be the one truck wonder in town. The simple math is the $100 you want is not what you need and the guy running 3, 4, 5, or what ever trucks at rock bottom prices is still making more money than you crying all over the board about your $100+ per hour rate. 8)
