Check Engine Light On My Everest
Torn
San Diego
Chris Thomas
I have an fairly new Everest with a little over a 1000 hours on it and I do not always use the auto pump out. A couple of days ago it filled up and the check engine light came on and did not turn off when I emptied the wast tank. Does anyone know how to reset it? Thanks
You sure your waste tank full float is not stuck? What happens when you bypass the tank kill circuit?
Torn
San Diego
Chris Thomas
I have not tried to do that. How do I bypass the tank and kill the circut?
joe harper
florida
joe harper
Just un-hook the Ground Wire on the battery....Then re-connect....
If the Light comes back on...Let us know..? This should re-set the circuit...
Torn
San Diego
Chris Thomas
I tried what you said and the light is still on.
Fort Worth , Texas
you should disconnect the bottom wire on the waste tank. let me know if this works.
do prochems have a computer or a control circuit board?
Torn
San Diego
Chris Thomas
I believe they just have circut boards. I'll find that out today and also try disconnecting the waste tank float wire to see if that helps. I'll get back to you a little later today. I have 2 jobs to do this morning though.
Thanks for the help
