Chem meter is rising when off the trigger
JS41035
Diaphragm. That's why that ball valve on the 870 and 2500 are nice. Order 2 when you get them. Because as much HP stuff as you do you'll need it. Out to be a 10 buck fix
1/2 inch swaglok check valve coming out of e2 exchanger is bad, replace it and good to go.
Reactions: dgardner
On the Butler it can be the Chem injection pump diaphragm with a bit of wear or hole but I have also found the pressure regulator can cause this trouble too
Jim ran himself off.
we both know that is not true but it is what it is...
@dealtimeman knows the answer.
Actually he had to call me to get the answer because he did not even know there was a check valve there....
If you get this one from windtrax......you will never ever have to worry about it again...thats what I put on mine...
Fvckin Lockheart, what a failure...
Thanks Jim!
As soon as I saw the diagram I recalled that part and its function. I had that one you got...
It failed too..
I know what you mean, if he will do that to the nicest of guys, imagine what he will do to the bad guys.
Sheesh
