chemical pump on vortex
steve frasier
portland oregon
steve frasier
looks like the diaphram went out on the chemical pump
there is no name or numbers on the stainless steel pump
gonna look local for the part but is there a rebuild kit for this or a better way to fix it
Hoody
Bowling Green, Ohio
Steven Hoodlebrink
You can replace the plastic disk
http://www.superiorcleaningsolutions.co ... 252/Detail
As well as the rubber diaphragm
http://www.superiorcleaningsolutions.co ... %2C/Detail
Take the stainless part off, it will unscrew, it should have a rectangular part to get a wrench on it. I like using a vise and a pipe wrench. Inside you'll find the plastic disk. There are small "crosshairs" on it, check to see if its flat or cracked, or if there is still a groove in it. The rubber part wears and needs to be replaced from time to time. Those chem pumps are only meant to be used at 600 a lower psi realistically for longevity. Running at a higher PSI will cause the plastic disk to break, and the rubber to wear down. It pulsates in order to create the vacuum on the chem pump line.
Your pump should look something like this.
George V
Hey Hoodie!
You got one of them that fits a Thermalwave 5m?
if so, could ya send it?
Thanx,
