Chemspec 4 jet DD Wand
Steve Smith
Does anyone have this wand or know what jets where used on it?
I believe the outside two jets are different than the two middle jets.
Who manufactured this wand for Chemspec?
Thanks.
Jesse
I've got a 12" sitting here. 4x11015 T jets.
I guarantee you cant make a worse multi jet, s-bend wand. It's comparable with Venturi's executioner 2 jet
Jeff M
I have 2 they sit in the shop never used what a P.O.S., they have 4 10015 jets in them.
Why would you want that for water extraction?
It's not a very good wand, but to each his own.
Made by Samco metals in CA.
Greenie;
Because the two slots pick up more water in one pass
(with a #5 Blower).
Larry, is that a theory, or have you seen it as fact?
The two slots only go up into the wand head about 3/4" then it is one common chamber. This larger footprint from the dual wand slots on the carpet makes this one of the most difficult wands to push on saturated carpet.
Greenie;
We did some crude testing with a SS Pump-out box system.
It did extract more water than the CMP 14" on saturated carpet.
I would use the 14' CMP for cleaning.
Larry:
Sometimes you remind me of those mill reps that used to come into my office extolling the virtues of polyester carpets.
Marty;
Polyester is way too high a quality fiber for your operation !!
Have you ever seen candy-stripe carpet ?
It's one row of "whatever fiber spool" they have left over...
Repeated hundreds of times across the width of the roll.
Larry, was the CMP one of the 1.75" varieties you sell? I know the DD wands are all 2" bore. that alone could account for the difference in vacuum. Also were both wands naked or glided, and if so, which glides?
Does that Candy Stripped carpet come in as high of quality as 14 oz, Larry? I may be interested.
