Chinese plastic virus?
Ive seen it, and there's some mentions of it on MB but have YOU personally seen where cheap plastic furniture legs have bled into carpet?
question came up in the S100 review
Yes, a few times.
To be clear, not first hand....but got calls about it.
For at least 10 years, first seen in new off-campus housing complexes. Brand new furniture, near permanent stains.
But they didn't care....
I've seen it on leather furniture. Both the legs bleeding and the center screw holding them onto the either rusting or leaching out a yellow chemical.
Reactions: Jimmy L and FB7777
The Great Oz
bryan
First saw this in a posh law firm 30+ years ago. All of their new chairs had plastic wheels, so the tech didn't consider them a problem. We were able to remove about half the ninety or so stains, and replaced the carpet in one office to use the remainder for inserts.
Since then every wheel or leg gets tabbed, blocked or the chair is put up to make sure it doesn't happen again.
FB7777
We had a similar situation
fortunately the customer was also a friend
he joked that it was great that had permanent marks so he knew exactly where to put the furniture when it was moved out to clean or vacuum
expensive furniture but plastic legs that looked like wood grain
30?
The pre and post inspection chapter is so inclusive, I'm surprised there isn't a mention already..
When anyone contacts me with a "potential claim level" damage call, the first question I ask is this:
"What is your relationship like with your customer? If they'd let you marry their daughter, this will be an easy fix. If they want your firstborn's blood as a sacrifice for your sins, nothing you do will get you out of this claim"
Lucky you on that one Fred.
Brian H
Brian H
I can remember black plastic caps for metal legs on a high-top table leaving permanent stains about 25 or so years ago. Each stain was about the size of a quarter. We trued everything to remove it and ended up retufting the area. The customer was satisfied.
I also had a child's plastic slide leave a permanent stain on carpet about 10 or so years ago. We had to replace that room of carpet.
jack zerkie
Iv'e had good luck with stain solve from Cobb sorry but a good product. Worked as long as the home owner has NOT used their home remedy I used stain solve and it was gone. The smell is a bit strong maybe thats why it works. jz
Reactions: Old Coastie
I caught it while the carpet was still wet and it rinsed out easy.
How many daughters are you allowed to marry?
