E
everfresh1
What do you guys use on brown stained carpet and furnture from heavy smoking? Any suggestions on removing this brown haze thats all over it? a good prespray for that purpose?
campusman1 said:this house was full of nicotine for ten years never been cleaned i used the judson juice 02 pre spray and extraction dont have the bottle in here but les knows who i am i called him for the formula 25 oz of 02 pre spray and 5 big table spoons of hot sauce les remembers here is the worst picture.
then I grabbed the Krud Kutter that we used for general cleaning
(I had never tried it for carpets at that time)
I mixed it at 6 to 1 ratio ...it flat out blew away the butyl (Ultrapac) and D'lime (Krush)
Cost RTU was about the same as the others.
everfresh1 said:Whats the PH of that stuff Larry? and what kind of carpet was it you used it on? would you have used it on the furniture?
dgardner said:everfresh1 said:Whats the PH of that stuff Larry? and what kind of carpet was it you used it on? would you have used it on the furniture?
(I know, I'm not Larry...) The MSDS lists the PH as less than 12.1. The Tech bulletin they put out lists carpet and upholstery as uses at 10:1 dilution:
http://www.krudkutter.com/tech_sheets/KK_tech_data.pdf
