Cimex scrub, Wand extract
Shorty
Cairns
Shorty Glanville
Following on from the many posts regarding Rotovacs, (all of them), RX20's, OP's & rotaries, I have not seen many posts where the operator has used a Cimex to scrub the carpet, then rinse/extracted with a wand.
Do many, or any of you, use this combination.??
If so, what do you think of the results.??
I have used this combination several times with my little truck mount, including scrubbing with the Mex, then rinse extracting with the old slow speed CMX20, and achieved brilliant results.
Thanks,
:roll:
ACE
Lawrence, KS
Mike Hughes
I have to do that every time at one of my restaurants with olefin carpet. It’s a good trick for extreme soil.
amazingcleansc
i dont see what would be horrible about doing releasit/cimex on carpet and then extracting with fresh water
ACE
Lawrence, KS
Mike Hughes
You need to use a prespray designed for HWE if you plan to HWE after a pre-scrub with the Cimex. Releasit and most encap products will foam up and kill your vacuum.
Zee
SoCal jungle
We have done the following hundreds of times: prespray with HF followed by cimex and then extract with truckmount (wand).
Brilliant results!
These days I prescrub -after my prespray is down- with my orbot and then extract.
amazingcleansc
Brilliant results!
i actually have really been enjoying using releasit ds and the cimex lately. Im going to show you what i did with an old la z boy chair on another thread
amazingcleansc
extraction powder foams up like a beyitch.
I think on second thought it might not be a good idea because releasit has flouro protector in it that you'd be rinsing up.
Ryan
For best results scrub then extract then encap the carpet. Takes a long time, but works wonders on extreme traffic lanes.
amazingcleansc
you arent taking into account the laziness factor AT ALL.
if youre going to be like that, then pile lift with a good stiff cylindrical brush machine first, vaccum then scrub prespray with a pad type machine.
and keep a pair of snips with you to get the odd out of place carpet fibers.
Dr Vapeur
Quebec, Quebec, Canada
Richard Gagne
I have been clean my chiro (about 2000 sq ft) for the past few years (my first commercial). The first time I did it with just a wand and prespray, looked good not perfect. The second time I used a sebo dual rotating scrubber, looked alot better. The last couple of time I used a cimex to scrub in the prespray. The difference blew me and my chiro away. Now, I always use the cimex to scrub. It does not take to much longer to do but does such a good job that I am proud of the carpet.
I have to thank this board for all the useful information.
Richard Gagne
Derek
NY
Derek
2-method cleaning will always beat a 1-method cleaning.
except for when the 2 methods are Capture followed by a Rug Dr.
I use the cimex scrub and rinse. Results are great of course. The only problem I have is that once u scrub with the cimex the carpet looks clean and therefore makes it hard to keep track of where I've been when rinsing.
lance
Thanks Richard. It seems that the white/tan pads are the most popular.
I have a Whittaker crb with blue brushes.....i think that might be a great scrubber just like the cimex. Great pics.
