Village Idiot
- Joined
- Jul 13, 2011
- Messages
- 26,344
This month's Saiger's Sauce Products Auction:
UN-EQUALED COMBINATION OF PROPRIETARY SURFACTANTS Our specific blend of wetting agents and emulsifiers are designed to remove tough oils and soils commonly found in upholstery fibers. Eloquence was designed for improved cleaning performance specifically for those difficult fine fabric/wool cleaning challenges. Eloquence has an un-equaled ability to cut through body oils, odors and every day household wear and tear of your fine fabrics and wool carpets/rugs.
POWERFUL CLEANING ABILITY FOR THE MOST DELICATE FIBERS Saiger’s “Eloquence” can also be used on carpets and rugs where a lower pH is needed. You will see incredible cleaning & brightening properties not typical of products in this pH range. Our proprietary blend is a non-foaming formulation, making it easier to use.
Saigers Tsunami Tile an Grout Cleaner is a high pH,"GIGANTIC WAVE of Clean" prespray! At the top of the pH scale, it's perfect for tile, grout, stone and concrete. It's also a great booster for super soiled Commercial, Poly, and Olefin carpets. This is not safe for wool or 5th generation nylon. Take care to wipe residue off items you might come in contact with. BEWARE: this product can remove some wax finish off VCT surfaces.
Ready to Use Unscented Solvent Based PENETRATING Fluorinated-Polymer works great on:
Carpet
Upholstery
Rugs
Textiles
AND
Tile and Grout & Stone Super Sealer
Total package value with Free shipping to the lower 48 States $303.96
Starting bid: $149
Minimum bid increment $5
Auction ends Wednesday March 9th at 9PM EST / 6PM PST
- One case Saiger's Super Sealer for Upholstery, Fine Fabrics, Wool, Tile and Grout and Stone
- One 6.5 pound tub Saiger's Tsunami Alkaline Tile and Grout Powdered prespray.
- One Gallon Saiger's Eloquence for Upholstery, Fine Fabrics and Wool prespray cleaner
ELOQUENCE is a very unique Upholstery, Fine Fabrics & Wool Pre-Spray Cleaner, which has been field tested by the Saiger Family for quality assured performance. Eloquence field testing was performed in many areas of the U.S. as to ensure maximum safe cleaning performance regardless of conditions.UN-EQUALED COMBINATION OF PROPRIETARY SURFACTANTS Our specific blend of wetting agents and emulsifiers are designed to remove tough oils and soils commonly found in upholstery fibers. Eloquence was designed for improved cleaning performance specifically for those difficult fine fabric/wool cleaning challenges. Eloquence has an un-equaled ability to cut through body oils, odors and every day household wear and tear of your fine fabrics and wool carpets/rugs.
Carpet
Upholstery
Rugs
Textiles
AND
Starting bid: $149
