I have told yall many times that I have seen many and I mean many carpet cleaning videos and if the situation ever arises I think, in fact I am confident I could clean some carpet if need be!!!!!
I know you have a short attention span, Topeka man. But part of the deal with the zipper having two vacuum slots is that usually you don't need to:NO dry passes???
You wet clean on the forward movement. The back glide will already pick a lot of moisture on the way forward, and the dry pull movement will actually extract twice... Lockhart pull-extracted with the Zipper and made two drying strokes (forward & back ). . .Larry
I still don't see the point of comparing a rotary extraction tool to a straight wand head (even if it has two vac slots)
If the zipper had 1 jet angled forward 1 jet angled backwards and so on (overall 3 would spray ahead and 3 behind) it might be interesting to see what it does. Erik, have you tried a manifold that was set up like that?
Maybe it came from the dirty areas.Even after a few cleaning passes with the cx and the zipper and having a few other guys that just happen to be in there and wanted to play as well made some passes, we hit the whole area with the trex jr and was surprised to see a good collection of sands and other soils on the head of the trex jr.
