Whatever you want to call it, this is the reason I was smoking my drive belts had minimal heat, and the worst extraction I ever experienced...I believed I was cleaning it often...but I also believe once the weather got cold maybe the silt turned solid and blocked it....Whatever it did...im glad I figured it out.as you can see in the picture the mash were I scrape off the solid buildup...
