- Joined
- Sep 15, 2007
- Messages
- 44,661
- Name
- bob vawter
I got a few PM's about my masking tape trick for a clutch install so i thought i'd post it.....
The clearance between the field and the magnet is measured in .000th.....
EXACTLY the thickness of masking tape.......so very carefully, wrap the magnet wit ONE wrap of tape...do NOT overlap!!!!firmly push the tape on and trim any overlap!
Set the magnet in the field and TIGHTEN center bolt 20 lbs torque....
THEN, tighten the four clutch bolts that hold the clutch assembly to the unit!
Once THAT is tight remove the center bolt back off and insert a 5/8 threaded bold into the center of clutch and this will force the magnet back off!
Remove the masking tape and install key in keyway Install the magnet back in field and re-insert center bolt and re-torque back to 20lbs......
The masking tape thickness is the clearance you need to keep from galling the clutch....
