Any year make model running on a 12V clutch. Or if I'm being ignorant of why that matters then 98 white magic pro 1200, ford 5.4, gas.
I need to get another used pto. I'm thinking of buying a used van and making my own pto or refabing an existing unit. I'll use the larger clutch and shaft that White magic uses on their HV, Custom heat exchangers.... Power and simplicity, economically is what I want.
I'm just wondering if there is any reason not to use an adjustable knob like I believe the
Vortex uses instead of the one of the preset systems the others use. I'd prefer to have the machine engaged at and idle then bring up the rpm's to a desired rpm.
