- Joined
- Oct 7, 2006
- Messages
- 10,877
- Name
- Jim Martin
SRI Cleaning said:[quote="steve g":32q7n3bu]jim your not being as clear as you need to be,I just checked my breaker box at home and it has twin 40 amp breakers that power my range plug. I then install cobbs power box on the range plug, does this give me a theoretical 80 amps of 110 power?? so you are saying due to cords and other inefficiencies I loose say 7 or 8 amps off this total. so I have 70ish amps of power to run what I want, so if each air mover draws 5 amps is it reasonable to expect to run 14 air movers at least in the above scenario?? does the cobb box look like it can flow that kind of juice?? am I missing something.
as a side note in my experience in order to reliably load a 15 amp breaker I need to stay at around 13.5 or less rated amps with my equipment. with the example I gave in the last post about 10 air movers on two 25 amp breakers in a 220 arrangement you are claiming I am only going to be able to run 4 or 5 in the real world situation, that is half the rated power, I don't believe this is accurate in my experience.
YES! you are pulling 2 legs of 120 at 40 amps each. You do have 80 amps of 120 available. or 40 amps of 240.[/quote:32q7n3bu]
so then why will a 20 amp breaker trip if you go over its rated amps ..??
