Quick Saiger Super Sealer Tutorial
Cleaning Professional
How does it compare to Hardball's protector?
Steve Lawrence
Steve Lawrence
How does it compare to Cobb's Impregnator?
Also, Mike. what is the width of your microfiber mop? From Amazon?
jmo
Jeremy
Can you use it on just cleaned carpet as well?
Reactions: Mark Saiger
Acp
Bjorn Marshall
any video of tests? Im just curious how a sealer can be that good on grout/stone but also safe for carpet. Dont you prefer color enhancing sealer for stone?
What's the best way to use it on showers?
Spray on, and if have your microfiber mop and can maneuver will work, but Contec has a nice short handle also.
Spray the wall first....and then use any residual on the shower floor....
It won't take much but walls could need couple treatments...and that can be done back to back really
Reactions: Living The Dream
I also have a video of treated couch cushion after it being encaped and I treated....then hit it with water after it sat an hour.
Will try to upload it.....
Living The Dream
Swani
Thanks again Mark!
Dont be a Texan.
So..... no testing?
You just referred to your testing, so there must be results for this testing right?
Or was this more like Bbq testing?
AND IF YOU DONT KNOW YET, I AM TEXAN, BIOTCH!
That was some expensive 5 second, 2nd grader testing and graphic skills, i see.
Just because cobbs no longer has adds here doesn’t mean I’m going to all the sudden jump to another product just because “someone says so”.
And y’all should know better.
Reactions: Jimmy L
More solids, less odor.
For the win.
Ok that’s what I was going for, that there wasn’t any actual side by side testing or any lab testing performed like when cobbs ultraseal and interlink supply’s sealer and maybe one other were sent off to a lab to ACTUALLY GET TESETED FOR soil, oil, and water Repellant properties.
So you could of just answered NO THERE WASNT TESTONG PERFORMED.
BUT I GET IT, YOU WERE STUCK IN CALIFORNIA FOR A VERY LONG TIME, SO I DONT BLAME YOU A 100 PERCENT, this miscommunication is only 90 perecer your fault!
Derrick
Derrick Schiffner
Has anyone had customers leave feet marks in the sealer? And walking makes a mess of footprints.
