ACE said:
What are you charging for commercial carpet cleaning?
If you offer some kind monthly stay clean maintenance program how are you charging for this service?
I have done little commercial work to date except for sub-contract. Rates around here are $.20 a square to less than $.10 but I’m not sure what the average is.
There are different options you can do for commercial carpet cleaning. First and foremost figure out what the customer is wanting. That will determine what options you offer them.
Give them several options, Annual Cleaning, Semi-Annual, 3 Times per year, and even 4 times per year.
Obviously with more frequency you CAN adjust the price a bit as your effort will be less and less the more they clean. If you have a cimex or a 175 you can do encap cleanings, and alternate between HWE and Encap on the appointments. At times you can get away with HWE once a year and encapping the 2nd, 3rd and even 4th appointment. Use your professional judgement to determine whats going to be best for them, as well as you.
You can break it down like such.
Annual:.25
Semi Annual:.20
3 Times per Year:.15
4 Times per Year:.10
Something to that effect. Figure out what you want to make on the job and price accordingly. Its easier to close on a commercial account by giving options, than just one price. Encapping is going to give you higher profitability, than HWE'ing every single appointment so remember to consider that option.
Hope that helps.
