campusman57 said:
ok thanks me and my helper i have two heavy 175 ill get some red pads we will do about 600 sq feet then extract with the green horn
use a red pad, just cause you asked about them suggests to me you shouldn't be using a green one.
It's VERY aggressive
Keep plenty pre-spray down with red pad too
two scrubbers running will blow one wand away.
Here's what we do;
the first man wheels in the scrubber, sets up and starts scrubbing.
Second man is setting up the TM.
By the time the TM is set up, the scrub man has a good head start and the scrubbed pre-spray has had a little dwell time to boot.
TM starts flush/rinse extracting and the scrub man continues to rock and roll.
The scrubber will out pace the wand
(unless you fly with a wand)
