tracywalker
I thought about going to look at this. Why do manufacturers not build something similar? Looks like you could get vortex power in a smaller package.
http://charlotte.craigslist.org/cto/4725714618.html
This system was built in Charlotte, NC by Charlotte Joint & Clutch (drive shafts & PTO) & Quality Machine (base plate & frame) in the year 2000. The inspiration for this design was the way in which a fire engine pumps water at a fire scene. Fire engines power the pump with the truck's engine & transmission by diverting power from the rear axle, to the pump, by way of a split-shaft in the drive train. I designed my system to work exactly the same way.
The system in comprised of the following: Chelsea PTO, Sutorbilt 5MP Vacuum, Cat 350 pressure pump, Butler heat exchanger, 38 gallon recovery tank, Hypro waste pump, White Magic electric vacuum reel, solution & fresh water reels, 200' vacuum hose, 150' solution hose.
Here is a video to demonstrate the power of this design & how easy it is to set up:
I am the original owner of this van. The odometer shows 336,202 miles & the machine hours are 5,051. The miles shown on the odometer reflect job time as well as road miles.
The following truck components have recently been replaced: Transmission, serpentine belt, radiator, upper & lower hoses, all filters, spark plugs & wires & exhaust system, wiper blades. The following machine components are brand new: Cat Pump, Butler Heat Exchanger, Pressure & Vacuum Gauges, Vacuum Tank Lid Gasket.
