I thought when
Prochem first came out with that design Bill Bruders said it was one that had been used before. So I don't believe it was an original idea.
Hi Richard
You are correct, Primatemp offered a product for a couple of years in the mid 90's that this is basically an exact copy of. These units are utilizing a axial fan blade which really reduces performance yet requires more amperage to produce a "fair" level of CFM and static pressure that was the issue with Primatemps. Prochem utilizes a impeller which is a better choice and technology that has been used in dehumidifiers as well as HEPA filters, for many years. However the triad misses the mark because they failed to engineer a solution to the fact that impeller's need a proper outlet channel design to "straighten" the air stream or it is very erratic.
This is just one of the patent pending features of the VELO and is quite evident when a person first views our unit.
We have been in the air mover biz now for 33 years and understand what's required to dry effectively and efficiently.
I'm sure several of the companies in this industry will rush substandard copies to market as they do time and time again. What I ask people to consider is a couple of age old sayings before they fall victim;
1. Buyer Beware!!!
2. If it sounds too good to be true it probably is
Have a great holiday weekend everyone
