Kellie Hiler
Is the CRB as good at scrubbing wood and laminate floors as a 175 would be?
The brushes would reach down and loosen soil if you run it parallel to flooring and then vacuum up dry soil.
I think a CRB would do a better job of dry cleaning factory finished wood floors that trap soil between the boards. The brushes would reach down and loosen soil if you run it parallel to flooring and then vacuum up dry soil.
