Custom Corner Guards???
jstucky
Jordan Stucky
Everyone make their own or order custom guards??
And what do you put on the back of them to make them not slide? Just rubber or foam glued on???
I had a local sheet metal shop make up some from aluminum. Had them bend in teeth on the bottom edges, basically duplicating other metal ones out there. Difference was, they cost me $12 each whereas the ones from the supplier were $25.
Any sign and wrap shop can spit out some laser cut stencils quick, apply them yourself. Just show them what you are after.
