We honed and polished a travertine floor last week (220-1800 5X) then the customer thought it was "too shiny" first time someone said "too shiny"...knocked it down a tad with 1500 honing powder with weight
Fiber Wooly lookin pads you use wit powders an a 175 correct.
Grits the same as sandpaper
Lower the number the more aggresive?
One day I may try this!
"Edited above, I need dilutions for Mopping it down"
similar to sandpaper, but easier to use. Must use wet to avoid trailing marks. If using diamonds, you go to the same grit as the pad grit, then down with the pad. So they say M1, M2 etc. it's 800, 1500 & 3000 then Lux. I go to 800 resin, then down with the 800 pad, or M1. The pads leave less of a shine then diamonds, but it looks better if you go up with diamonds, then down with the pad, as opposed to trying to progress to the next step with the pads. 400 diamonds then 800 pad won't leave as nice of a finish.
It looks good, but that floor is going to wear down extremely fast. If they have any pets or guests, or a mop, they're not going to be happy.
Cam, can you expand on this
