CX15
I recently traded my Powrflyte multi-wash for a CX15. Virtually brand new. Haven't used it yet. Not sure if it's something I should keep or sell. Who has used one successfully? When and where? Any problems with rings on the carpet? What psi?
Reactions: Living The Dream
Can you imagine how good it could be if it had a rear vacuum lip like the Zipper?
It's the crop circles it makes when you initially trigger it, that have held back its usefulness. They can be very difficult to remove. It's best for low pile commercial carpet with wide open spaces.
A Zipper is much more versatile and controlled much better.
I tested it at a distributor once and that's what was happening. Have to be moving before triggering the wand and make sure you are using the right spray bar. You don't want to use the commercial one on residential.
It just seems like it controls how you clean instead of you controlling it. Not useless but a Zipper spinner is a far better tool.
I've listed it for sale for $950. See if I get any takers. I have some apartment building hallways coming up. I may try it out. Very light tool but would help if I had someone to manage hoses.
sassyotto
Paul
should be a whole nuther thread on this.
Hose pulling helpers are like......... or
Carpet cleaners that need helpers to pull hoses are.................
My hose comes in 50’ sections that actually COME APART.
I don't think you get it. These are not houses I am cleaning. We consistently run over 300 ft of hose. There is no time to add or remove any until near the end of the job. You cannot clean your in, up the stairs to the third floor. Not going to happen.
