Descaling truckmount
Tom Forsythe
Credits
938
Points
938
The hardness of your water and the heat of the machine impacts how often you should descale your machine. Ask your local mechanic and he will have a better answer to you question.
sassyotto
Wisconsin
Credits
1,666
Points
1,666
Paul
I run a water softener and have never had to descale. I take my machine to Jon Don every year for annual maintenance and they always said that it didnt need it. EXCEPT once where a new tech did it "because it was on the Prochem checklist" even tho it didnt need it. UGH!
Reactions: Matt Wood
Swani
Montana
Credits
4,680
Points
4,680
Nick
If you start to notice white build on your quick connects you probably need it. You can use vinegar or something like fab set in a pinch but it's best to use an actual descaler. I use one from Bridgepoint.
cape coral fl.
Credits
1,110
Points
1,110
You can laugh but I use the water magnet no soft water but no hard water build up. My Hydramaster 470 D had it from the factory. Never had a problem. My Cobby unit is 8 yrs and I use the magnet all the time. Very hard water here in paradise but still no build up. jz
Top
