Doug Cox
I have one that I used for a couple of weeks and decided to go with the SS CDV filter box. If anyone is looking for one, I will make you a fair deal on an almost new one. 262-352-4724.
Easy to buy another lid. I keep two on the van2.5 on both ends.
Aesthetically, mine looks like a tin can, more or less, and can appear beat up looking fairly easily; they roll over sometimes, which looks sloppy, and causes the "beat-up" look I described.Obviously they still have overwhelming support, but that's 3 guys now who arent crazy about their Dev filter.
What's not to love? I'm just about to buy one this spring.
Only a talking fence post that thinks it knows shit that it doesn't and talks out it's latch. But then fence posts talk in your world, not mine.You'll argue with a fence post, I know that for sure.
I had to adjust the latches right after I got it, but at least the latches are adjustable. The main problem I have is trying to clean out the filter bags. Just too much work IMO. The CDV filter boxes filter is more fine than the waste tank filter. I just cleaned out my waste tank for the first time since I bought the machine in September and have a whopping baseball sized ball of dust from the tank. Pretty good IMO.I'm amazed. I've been using Dev filters for, I guess, 5 years now, and I don't recall ever adjusting the latches or having my top leak due to the bag not fitting,
Am I just more mechanically inclined than you pervs?
Do you run a paint filter in the dev filter? I just use a spray gun to wash down debris to the bottom through the day then dump it out at the end of the day.I had to adjust the latches right after I got it, but at least the latches are adjustable. The main problem I have is trying to clean out the filter bags. Just too much work IMO. The CDV filter boxes filter is more fine than the waste tank filter. I just cleaned out my waste tank for the first time since I bought the machine in September and have a whopping baseball sized ball of dust from the tank. Pretty good IMO.
