steve frasier
I have been maintaining some polished concrete with 3000 grit diamond pads on an auto scrubber and a propane buffer
put a denisifer in the auto scrubber, do a double scrub, soak pass and then a vacuum pass with the 3000 grit pad
if the floor has a little wear on it then I go over it first with a 2000 grit pad then go over it with the 3000
buff with propane buffer, with either a hogs hair or the 3000 grit pad
everytime I clean it, the shine seems to improve
it actually has more shine now then when it was first polished
