renegade_cowboy
I never used a chemical injection system and curious how it differs from a water box and what are all the components that go with it. And how does the cost differ?
Thanks
Thanks
ACE said:What machine are you running? I though most hydramasters had last step CI. Water box has nothing to do with chemicals. The water box is used to pre heat water and as a buffer zone for high incoming pressure that could damage pumps.
There are pros and cons to both chemical injection and chemical draw systems.
Chemical Injection: Pros: It will not “cook” your chemicals or run chemicals through heat exchanger. Cons: most systems cannot be run at high PSI.
Chemical Draw: Pros: High Psi Cleaning. Cons: If you run out of chemical or have a small leak pressure will not work at all. Runs chemicals through your all of your high pressure pluming.
