divider wall
realclean
Jesse Lowe
I am looking for some ideas for a wall to divide the cab of my Chevy van from the back. I would like it to be as air tight as possible. I would also like it to have a window so I can see.
C&S
divider
Interlink sells a divider for $200 ish. I've thought about getting one, but in the winter I wouldn't use it as it gets very freaking cold where I am.
Shane T
Shane Tiegs
2004Chevvan002.jpg This is what I've done on a couple of my vans. I love it. You can see it goes straight across so I did loose some room for the seat to slide back but I'm only 5'7" so that's okay for me. If I have tall passengers its a little tight for them. You could angle it back like the metal ones for more cab room. It is secured to each side and I bolted a length of angle iron to floor to secure the bottom. The center section can be removed from the cab side.
realclean
Jesse Lowe
2 questions. Do you have a photo from the cab side? and how did you fasten to the wall and roof?
Shane T
Shane Tiegs
The sides are secured with metal screws to the ribs in that location and the top is not attached. This pic shows a piece of plywood I put across the top for rigidity. TM004.jpg I don't have a pic of the cab side at this time. I'll work on it.
