gimmeagig
The flowmeter on my CDS seems to be acting up a little bit.
When I used to set the mixture that little indicator would float on a solid flow of water but recently there are all these bubbles coming up. It still shows my GPH but I'm not sure if it's accurate. Also on the back where the solution comes in it leaks a little bit. Not much. A few drops.I unscrewed the smaller brass screw and cleaned the threads put a little teflon paste and wrapped it with teflon tape.I tightened it as much as it seemed safe but I think the water comes from the larger brass part that the fitting goes into. The Flowmeter is about 90.- on e-bay and I don't really want to spend the money. Should I just put some silicone around where it leaks and call it good?
