- Joined
- Aug 9, 2012
- Messages
- 11,559
- Name
- sam miller
I'm limited to 60 gallons supply and limited heat with the Legend as well.
So I have been becoming more "creative" trying to get the same results with less flow/more heat.
You can get an amazing amount of work done with less than 60 gallons including tile and grout.
True the key is pre spray, using a multi sprayer and they’re water to pre treat.
Good agitation and dwell time then a lower flow rinse especially after you @Ron Werner the carpet with a vacuum
