Brian R said:
.but it can't be too high of pressure without enough volume either...like the cheap pressure washers etc.
I was just sayin
the cheap pressure washers are just the opposite of the low psi higher volume sprayers.
They're hi-psi/low volume
a GPM is a GPM , regardless of the psi.
you don't need psi for pre-spray anyway..you need volume
ever bucket tested any of your sprayers to actually "know" what the GPM is??
If you have an 06 jet in your soap on a rope (HF on a hose) you "might" be getting 3/4 GPH
