Drimaster Upholstery Tool Survey
danpauselius
Yes and I use an internal jet tool for anything that is actually soiled. DM tool is good for some of the more delicate items.
B&BGaryC
B&BGaryC
Yes, have used.
Have now"? No
Will buy? Maybe later...
Happy with it? You bet!
Just yes or no? you oughta know me better than that.
B&BGaryC
B&BGaryC
Call me a twit, but my favorite upholstery tool is actually an external jet prochem tool. On things that don't need to be "blasted", I just adjust the water, and spray a mist of rinse water over the pre-sprayed upholstery and extract it all. It still cleans like a son-of-a-gun and gets it done in no time flat.
Loren Egland
Loren Egland
No drimaster.
Have PMF internal jet tool and occasionally use it.
Have standard tool.
Have two styles of Hydroplane tool.
Have and use two styles of Hydrokinetic tool.
Loren
Michael Ellis
Michael Ellis
Yes...have two and pressure control is not a worry when duel cleaning. Safe agitation in forward and back stroke while lofting the fabric away from the batting and cushion make it a great tool. I could say dual but duel really makes sense since an upholstery and carpet or tile job done simultaneously is a duel in way :)
Terry
Terry O'Brien
yes easy to use among many advantages biggest negative is waste of water
Not any more. Its in my supply room. Hasn't been touched since Sept.
Bought the SteamWay Hydrokinetic with a glide. Blows the DM out of the water. Uses more water, leaves fabric drier. Can use all the heat and vacuum the TM produces.
Shorty
Shorty Glanville
Quote:
"1 little nick on the metal plate and the spray is messed up"
Unquote:
Question, how are you going to get "1 little nick on the metal plate".
I thought we were cleaning fabric upholstery with this tool ??
I've had my old plastic (?) Drimaster for a bloody long time, and still not managed to stuff it up.
Then again, owner operators take more care of things that turn crap into dollars than what staff do :wink:
Ooroo from down under
:roll:
Jack May
That Kiwi
John
Right on that one Shorty.
My original DM is about 6 years old and was going strong till I put it into the other van... STUFFED.
He thought a screw driver would clear out a few of those nicks.
The new DM is STILL NOT IN NZ :( empty promises. Last I heard was 4-6 weeks... I'll wait to see if they meant months. Apparently, HM have had supply issues keeping up, or so I've been told.
John
