Drippy Wand,
Westpak offers external check valves,Joe Bristor sells internal versions
I prefer the external option.
the wand trigger pin valve may need repair or replacement.
those same people sell wand kit replacement or repair kits
John Olson
John Olson
I've got the stubbies in stock but most likely you need a rebuild kit in your wand if it is leaking excessively and constantly. Call Monday and ill hook you up. Think ill add these to our CAD super specials list.
Hey Mikey ... I assume you can't purchase the external check valves directly from West Pak ... so where do you get them from?
I am all for the extensions....but don't waste your money thinking they are going to stop the drips.....the cracking pressure on them is so low...once the wand valve starts leaking past...they will drip anyway....
your best bet it to keep a healthy wand valve.......
