juniorc82 said:
I have a cheap 2 jet economy wand. I was thinking of upgrading to a 4 jet wand. The 4 jet wand I saw looked like the jets were a bit closer to the floor (maybe I will save some heat?) also didnt know if the added jets make a differance( not sure what they are jetted at ). give me your opinion I dont want to buy another wand if it will make no differance
you're running a porty, stay with the 2 jet AW29 that came with your Recoil.
(and most other portys)
the AW29 is actually a very good cleaning wand at low to moderate PSI.
Believe it or not, that cheap ole aw29 cleans better than a pimped Ti wand at 350 psi and under
at higher pressures it and other wands that have jets blowing straight down tend to inject too much spray into the backing on some carpets .
(like inexpensive cut piles)
stick a set of 03 flow jets in that wand and keep the PSI at or below 300 and you'll be in tall cotton
