Dual wand system ??
nusteem
Is there a way or a device to regulate the pressure on a pump to create a dual wand system.(that will balance the pressure flow) I could rig another pressure pump up, but is there another way??
thanks
We just crank the PSI up another 100 psi when using dual wands. You can geta spikes when one doesn't trigger at the same time but for the most part it isn't noticeable or a problem in cleaning.
Arizona
here is where I can see something like this being made more portable to snap in between the wand and the line...crank your PSI all the way up and have each guy set there sweet spot for where they want to clean....
nusteem
I picture is worth a thousand words, but could you explain more about what is in the picture for me??
Thanks
