Dump Valve
Goldenboy
Mike Waldron
My dump valve is leaking. I seek water bubbling up in the tank. Where can I buy one? How much? I think it is 2 inch. Is it a big deal if it is leaking?
Golden Boy
Call your regular supplier, $15 problem solved, it's a quick swap out.
Wait...this is Veeg's estranged kid, you will need to schedule an appt. with the locla supplier, and pay the shop rates to have it installed, just a $100 problem, call pops ask for an advance on your allowance.
Goldenboy
Mike Waldron
100 bucks? Holy crap. The baby is still in diapers. Do you think that is causing a lot of foam in my waste tank?
Golden Boy
Goldenboy
Mike Waldron
Harold dont be a Hater. Help a brother from the trenches out.
Golden Boy
steve frasier
if you jiggle the handle a little that will usually stop toilet leaking
if that doesn't help then go see that dr. that puts on the rubber glove before he checks your prostate
is it a knife valve or a ball valve?
If you don't know the difference, a knife valve has a Tee handle on top that you pull up.
If it's a ball valve it will have a lever on the side that you push or pull down.
It works the same as the shut off valve on the end of your solution line.
Only much bigger.
If it's a ball valve, you can buy them at any plumbing supplier.
Don't know if the big box DIY stores have them that big or not.
If it's a knife valve, you can buy them at most places that sell campers
Either valve just screws on.
Yes a leaky waste valve can cause foam in the tank.
damn, you really are inept aren't you?
Does Mrs Waldo tie your shoes for you in the morning?
or did she teach you to use the velcro strap kind....
