Dwell One Portable Extractor AUCTION
MB Auctions
The Work Horse!
Great for Carpet, Tile and Upholstery
Watch the video for more details
Package includes hoses and cords
No wand
No heater
Perfect for rug plants or large hotel and resort accounts
As durable as they come and very easy to work on
$4800 retail value
Auction starts at $2000 and includes free shipping to the lower 48
Cool, Sam Miller is smart enough to see the great value here.
Sam do you currently have accounts that this unit will excell on or will you go hunting or will it be a back up/occassional sort of thing.
dwellpro
usa
m
No machine manufacturing website at this time. It is in process. Currently I only lease machines to hotels and exclusively use them with my service business.
dwellpro
usa
m
We may not have a web page but we are in full production of the Dwell#1
John Olson
Orem UT
John Olson
Um Mike yes you have used a RV XL that is the Rotovac XL you have bought 2 of them from me :)
dwellpro
usa
m
Yes in deed John. Thank you for the correction. Did not know the abbreviation RV my bad.
I actually bought three from you. The Westin Savannah uses it with the Dwell#2 machine. So much function space down there! I also sent one to the St. Regis, Atlanta.
Both hotels also have a RV360. Of course I have one XL and several 360's.
I will say I am very careful with water pressure when using this device with any of my machines. Second, Third pass air only is recommended.
Please note that the dwell#1 and Dwell#2 have the same 3 stage vacuum configuration. Also the same 2 hp motor and discharge pump. The Dwell#1 can get 50 feet away from the water source. The Dwell#2 can get 100 feet away from the water source and has a built-in proportional metering pre-spray pump. This water driven pump is attached to a 50ft retractable reel. One operator pre-sprays while the other cleans simultaneously.
Reactions: tracywalker
love the simple prespray and rinse set up.
So how long does the gallon of rinse last?
Are you able to meter the prespray for 32 or 64 to one options?
dwellpro
usa
m
Three different options with the Dema mix right chemical injector.
The first one is high percentage injection used with tile and stone cleaning.
The second and third are the most commonly used. The third being the most versatile in my opinion.
I'd say the 10,000 square-foot ballroom takes a gallon.
dgardner
Phoenix, AZ
Dan Gardner
Mike, is that the right video? All I see is a quick inrush of current then zero, and the video stops at 1:26....
dwellpro
usa
m
Yes it's true! The Dwell#1 works off of magic. You actually do not need to ever plug it in the wall at all!
LOL
Standby. Uploading...
Reactions: dgardner
dgardner
Phoenix, AZ
Dan Gardner
So it looks like you're running about 1000 psi at probably 2 gpm - 13A is right on the money for that.
The amp draw on the vacs could be an issue in older residential, but will not cause any problems most of the time.
Thanks for the demo!
Reactions: Lee Stockwell
dwellpro
usa
m
I saw TOOL in Vegas this year. Such perfection. I aspire to be that accurate. Jambi is my favorite.
dwellpro
usa
m
it was 800psi. 1500 TO 800 with the NEW SX-7 head. Lets test the old SX-7 head next and see the difference...
