Captain Cleantastic said:
My Dwyer meter wont keep working. The Bullet keeps getting stuck down. I take it apart and put it back together and it works a few days. I cant see anything wrong with it or find what is making it stick.
it doesn't take a very big piece of grit/dirt to stick the ball, Brian.
are you sure your tank is clean?
are you "sure" it's flowing at all?
next time it sticks, try this;
put a naked QD on the end of the solution line so water will flow full flow.
Turn the pump on and off a couple times .
See if the ball jumps at all.
if not....
if you have a hi-pressure setting on your pump, turn it to hi and turn the pump on and off a couple times and see what happens
