Edging wand or ?
Walt
The 360i runs well at 300 psi. My ti wand does not. It likes a min. of 400 psi.
I realize I can set the tm at 500 if I want and feather the 360i with the little valve. That's clunky and inaccurate. Or I can go back and forth between the machine turning pressure up
And down, which is slow. Maybe I could put a permanent flow restrictor on the 360i to
Reduce the pressure from 500 to 300.
Or I could just get a new wand for edging. Something with more impact at lower pressure.
Walt
Yes. But it's easy to bump the valve and send it to full. Also, it's not very accurate.
an AW29 is a good cleaning wand at 300 psi.
if you like the way the Greenhorn stair tool cleans, you should like the AW29...cause they're pretty similar as far as the head and jets are concerned
I'm Rick James
Whos that guy that made the aw29 knock offs... he gave a few free ones away a couple of years ago on here..?
alazo1
Albert Lazo
Check out the 4" wand from Magicwand if it's for edging. Works great for filtration lines and spotting too.
Albert
