TomV
Finally getting around to building an electric truckmount.
Four 3 stage lamb vacs connected to a 55 litre polypropylene rotomoulded recovery tank configured as 2x2 in series units.
1x auto shutoff switch on the recovery tank
1 x auto pump out (capacity 4000 litres ph)
300 psi solution pump
1 x 2.8kw inline water heater producing c.200 deg heat at the wand
1 x 60 litre polypropylene water tank with chemical metering and demand intake (float valve) so it can be connected to a tap with no overflow risk.
2 in vacuum hose
power draw is projected at 16 amps (220 V supply)
Unit foot print approx 14in x 25 x 25.
As my work is mainly residential I'd happily stick as a porty guy but i want more vacuum, plus... I wanna build one.
Any insights, or tips /suggestions would be welcome cos i know ive forgot a shit load.
And Cu..no, its not goin in a ****in Connect in dublin.
2 in vacuum hose
