Encap using Cimex and Release It
asupremeclean
What is the most efficient way to clean commercial grade carpet with this combo?
How do you do it?
Do you Pre-Spray the product or use the tank?
What is the ratio for the pre-spray?
DO you need to agitate Product?
You can either FLOOD N' RUN or SPRAY then SCRUB N' RUN.
Oh yeah make sure you pre vac first because THAT is the cleaning step!
breathe72
Jimmy you really helped this guy out. Dick.
When you gonna start carrying a vacuum on your van?
John Watson
We use the tank and dilute as per the label. I will mix a qt for my sprayer a a stronger dilution to pre spray spots before I get to them
GRHeacock
Generally speaking, if you apply with the shampoo tank, that will put less fumes into the air.
Plus it is a lot quicker.
Gary
Rick, I noticed you did not correct anyone's spelling on this thread. No dash. No Space. Correct?
Scott Warrington :)
