Encapping with a 175
encapman
Rick Gelinas
Use your shower feed from the tank on your rotary. Don’t use a Multi-sprayer. You’ll get much better control of your solution flow using a tank.
Use Fiberplus pads if you have them (they’re formulated for carpet scrubbing) or use a buffing pad if you don’t have access to Fiberplus pads.
Solution feeding through the Fiberplus pads gives you even and smooth coverage. Production with a rotary won’t be quite as high as the Cimex. Cimex planetary scrubbing produces far more agitation. But a rotary would make a nice addition to your Cimex to bang out a large job
Reactions: Walrus Gumboot
